Palit GeForce RTX 2080 Super JetStream Review
October 12, 2018 | 13:00
Tags: #cuda-core #dlss #geforce-rtx-2080 #gpu #graphics-card #rt-core #tensor-core #turing
Companies: #nvidia #palit
Test Setup
Our GPU test rig uses Intel's Z370 platform. Specifically, we use the Asus ROG Maximus X Hero paired with an Intel Core i7-8700K. With six cores and 12 threads via HyperThreading, the CPU ensures even the most multi-threaded games won't be bottlenecked, and we've overclocked it to 5GHz as well with a base clock of 100MHz, a multiplier of 50 and a vcore of 1.3V, further alleviating CPU bottlenecks. The CPU is paired with 32GB (4 x 8GB) of Corsair Vengeance RGB DDR4 clocked at 3,200MHz and cooled by a Corsair Hydro Series H100i V2.
The rig is powered by the Corsair AX1500i, which has enough wattage and eight-pin PCIe power connectors to deal with any multi-GPU set-up we care to throw at it. It's all housed inside a Corsair Carbide Series Air 740, which is spacious enough for any card. The final component is an OCZ Vector 180 960GB SSD, giving us plenty of space for game installs.
Our results come from a mix of built-in benchmarks and custom, manually played sections, depending on the game. All benchmarks are repeated at least three times to ensure consistency. We test at 1,920 x 1,080 (1080p), 2,560 x 1,440 (1440p), and 3,840 x 2,160 (4K), though some resolutions are excluded if they are deemed inappropriate for a certain card. The operating system is an up-to-date copy of Windows 10 64-bit.
Test System
AMD Graphics Cards
  • AMD Radeon RX Vega 64 8GB - 1,274MHz GPU (1,546MHz boost), 1.89Gbps HBM2 (Radeon Software Adrenalin 18.9.1)
Nvidia Graphics Cards
  • Zotac Gaming GeForce RTX 2080 Ti Amp Edition - 1,350MHz GPU (1,665MHz boost), 14Gbps GDDR6 (GeForce 411.63)
  • Nvidia GeForce RTX 2080 Ti Founders Edition - 1,350MHz GPU (1,635MHz boost), 14Gbps GDDR6 (GeForce 411.51)
  • Palit GeForce RTX 2080 Super JetStream - 1,515MHz GPU (1,860MHz boost), 14Gbps GDDR6 (GeForce 411.63)
  • Nvidia GeForce RTX 2080 Founders Edition - 1,515MHz GPU (1,800MHz boost), 14Gbps GDDR6 (GeForce 411.51)
  • Aorus GeForce GTX 1080 Ti 11GB - 1,569MHz GPU (1,683MHz boost), 11Gbps GDDR5X (GeForce 399.24)
  • EVGA GeForce GTX 1080 FTW 8GB - 1,721MHz GPU (1,860MHz boost), 10Gbps GDDR5X (GeForce 399.24)
Mod of the Month June 2020 in Association with Corsair
July 1 2020 | 17:34
