SilverStone Raven RVX01 Review
December 30, 2015 | 11:28
Tags: #air-cooling #atx-chassis #rotated-motherboard
Companies: #silverstone
Cooling Performance
For cases capable of housing ATX or larger motherboards, we use our standard ATX case test kit, which includes:
We disable the motherboard's onboard CPU fan control and all CPU power management features. The CPU fan is fixed at 7V with an adaptor while the graphics card fan is locked at 70 percent speed using MSI Afterburner. The system is loaded using Prime95 25.11 and Unigine's Heaven 4.0 benchmark. We use Core Temp and GPU-Z to monitor the temperatures, taking the maximum values after 15 minutes - enough time for the readings to plateau.
Case performance - CPU Delta T
Difference over ambient
  • SilverStone Raven RVX01
  • Cooler Master MasterCase Pro 5
  • No case - open test bench
  • Corsair Carbide Series 600C (max speed)
  • Be Quiet! Silent Base 600 (max speed)
  • Corsair Carbide Series 600C (med speed)
  • Corsair Carbide Series 600C (min speed)
  • BitFenix Pandora ATX
  • Be Quiet! Silent Base 600 (med speed)
  • BitFenix Nova
  • Be Quiet! Silent Base 600 (min speed)
    • 50
    • 52
    • 54
    • 55
    • 56
    • 56
    • 56
    • 59
    • 60
    • 60
    • 62
20
30
40
50
60
°C, lower is better
  • CPU delta T
Case performance - GPU Delta T
  • BitFenix Nova
    • 47
    • 47
    • 48
    • 48
    • 49
    • 51
    • 52
    • 53
    • 53
    • 55
    • 55
20
30
40
50
60
°C, lower is better
  • GPU delta T
Corsair HS60 Haptic Headset Review
October 15 2020 | 14:00
